W220 s320cdi limp mode switch on off
Old Oct 4, 2017 | 02:37 PM
Granty's Avatar
Default W220 s320cdi limp mode switch on off
Hello my s320cdi starts fine drives fine for a few minutes then goes into limp mode won't rev over 3k revs unless while driving I switch ignition off then on and it drives fine antil I have to stop in traffic then it goes back in limp mode, antil I repeat the on off procedure! Any advice would be most appreciated
Old Oct 4, 2017 | 03:18 PM
PelicanParts.com's Avatar
Hello - are you able to pull any codes?
Old Oct 4, 2017 | 03:23 PM
Granty's Avatar
No codes but was told turbo boost sensor if that means anything to you? Thanks for reply by the way
Old Oct 4, 2017 | 04:17 PM
That makes sense since you have a diesel engine; that sensor is essentially there to protect the turbo. When you had the diagnostic done, did they say anything about the waste-gate hose failing?
Old Oct 4, 2017 | 04:25 PM
Granty's Avatar
No but I have a leaking pipe which lead to valve type thing near balk head same as one new turbo egr related repaired that but still the same. If i start engine and move straight off its fine but when the revs get to low it goes into limp. I appreciate your help
Divesh Nath
Oct 29, 2020 05:05 AM
Granty
Sep 13, 2017 12:18 PM
cmarksmith
Apr 28, 2009 05:33 PM
barrieeld
Sep 2, 2007 01:22 PM
briankfaucher
Mar 19, 2004 02:18 AM
