W220 s320cdi limp mode switch on off
Hello my s320cdi starts fine drives fine for a few minutes then goes into limp mode won't rev over 3k revs unless while driving I switch ignition off then on and it drives fine antil I have to stop in traffic then it goes back in limp mode, antil I repeat the on off procedure! Any advice would be most appreciated
Hello - are you able to pull any codes?
Originally Posted by PelicanParts.com
(Post 174370)
That makes sense since you have a diesel engine; that sensor is essentially there to protect the turbo. When you had the diagnostic done, did they say anything about the waste-gate hose failing?
Originally Posted by Granty
(Post 174371)
No codes but was told turbo boost sensor if that means anything to you? Thanks for reply by the way
(Post 174372)
