Rear drops 2002 s320cdi
Old Sep 10, 2017 | 09:09 AM
Granty's Avatar
Default Rear drops 2002 s320cdi
Hello I bought a 2002 s320cdi when I turn the engine off the rear drops down very low when I restart it the red low suspension warning shows then I push the button and it lifts, no malfunction shows but the cars in limp mode but sometimes the suspension fault warning shows and it comes out of limp mode and when the warning goes out it goes back into limp mode. Any help would be much appreciated
Old Sep 11, 2017 | 12:26 PM
PelicanParts.com's Avatar
Hello and welcome to the forum! I would try pulling the codes - this should give you a definitive answer as to what is going on.
Old Sep 11, 2017 | 01:13 PM
Granty's Avatar
Thanks for reply I've had it on a sealy code reader showed none does it need to go on a merc machine cheers
Old Sep 12, 2017 | 11:28 AM
Other members should chime in, but I would think that since you're getting a warning light that there would be stored codes on the unit.
Old Sep 12, 2017 | 11:36 AM
Granty's Avatar
The warning seems to come on in morning and then it's out of limp mode but It soon goes out then theres no malfunction. It drops mainly on the n/s/r to the floor but also o/s/r there's clearly got to be an air leak but the limp mode thing is a strange one. Thanks again for replying
Old Sep 13, 2017 | 03:04 AM
Granty's Avatar
This morning the rear was down started car rear lifted airmatic fault came on drove fine out of limp mode then the red to low warning came on still out of limp mode stopped turned of and restarted still red warning carried on and about a mile down the road no malfunction car rose and was fine for rest of journey but in limp mode! Any ideas it shows no codescheers
Old Sep 13, 2017 | 12:18 PM
It seems like there is leak in the air system, I don't know the procedure to check for the leak - other members should chime in here. Sorry that I could not be of more help!
Divesh Nath
Oct 29, 2020 05:05 AM
dfieldsh
May 21, 2016 01:45 PM
b06mbj
Apr 22, 2012 10:17 PM
barrieeld
Sep 2, 2007 01:22 PM
sniewl
Feb 2, 2004 04:28 AM
