W220 4matic lower control arm parts
Old Aug 10, 2017 | 09:06 AM
jchoffman12345's Avatar
Default W220 4matic lower control arm parts
Ladies and Gentlemen:
I have an issue with my lower control arm. My car did not pass safety inspection due to torn bushings. I have replaced the bushings and ball joint, but now my repair center is telling me the small ball joint at the base of the air spring is bad, thus a replacement control arm. My question. Is there a source for the center ball joint that connects to the bottom of the air spring? I have searched the forum and internet without success. I also have the alldatadiy service and cannot find it there. Help sourcing this part would be great.
Thank you,
First time poster,
John
Old Aug 10, 2017 | 01:28 PM
PelicanParts.com's Avatar
Hello and welcome to the forum John! Feel free to give us a call at 888-280-7799 and one of our MB part specialists may be able to help you with the part or suggest an alternative. Best of luck!
Old Aug 24, 2017 | 02:24 PM
Default Fixed
After intensive searching I was not successful in finding a solution to the bad ball joint at the base of the air spring. I also was backed into getting the car back on the road. Both lower control arms are now replaced and an alignment. I hope I am good to go for a while.
Thank you,
John Hoffman
Old Sep 10, 2017 | 05:05 AM
mybenz17's Avatar
But it is not enough safety you need to fix it before using and ask for more technical opinion with the car expert to give you more proper advises
philipk2003
Dec 8, 2009 12:11 PM
joemal
Jun 18, 2008 10:23 PM
Benz_190
Mar 3, 2006 04:43 AM
R129
Feb 17, 2005 03:33 AM
