navigation question
Old Jun 10, 2012 | 07:36 PM
PB736's Avatar
Angry navigation question
2004 Mercedes S 430. Suddenly showing position in pacific ocean. Says Navigation not active. Can not do any thing with GPS/Maps.I did reset command. Took out CG for navigation and put it back. No better.
Any suggestions:
Old Jun 10, 2012 | 08:40 PM
chassis221's Avatar
usually a bad antenna .
Old Jun 10, 2012 | 09:15 PM
PB736's Avatar
Red face navigation s430
Can I buy on net and replace it. or its a tough job
Old Jun 11, 2012 | 06:52 PM
chassis221's Avatar
It is something you can do. but it can be a real pain in the ***. Depends if your antenna is on the rear glass or on the trunk lid. If your antenna is o.n the rear glass the antenna wires run along either side of the rear glass. you need to make sure you properly seat the wires. make sure when you are pulling out of the wires you pay attention to the correct position of wire routing. there is a oval shaped rubber gromets on either side below the rear glass. you also might need to remove some trunk panels to access the wire connections.
Old Jul 8, 2012 | 12:51 PM
TexasLowell's Avatar
Default Cheap Fix for Bad Antenna
I had the same problem. I could not figure out how the antenna connected and apparently someone in the past had the same problem and the antenna was just stuck up there with no connections. It looked like an expensive and hard task to fix it. I went to eBay and bought a cheap antenna that came from China. It was just $12 or so. I plugged it in and put it on my rear fender just running the wire inside the trunk. I plugged the new antenna into the side of the splitter with one wire. I immediately got 7 or 8 satelites. Problem solved and cheap.
Old Sep 11, 2012 | 09:23 AM
g9blues@aol.com's Avatar
If still having problem try disconecting the box in the trunk for a little while then plug it back in, you should see results. The box comes out by pushing in the clip on both side. Good Luck!
TPARK
Dec 20, 2015 09:34 AM
cobra9898
Aug 20, 2007 04:08 AM
cpunnose
Jan 29, 2006 09:10 PM
ecwlukeny
Jan 20, 2006 02:29 AM
*marie*
Nov 18, 2005 05:47 AM
