navigation question
2004 Mercedes S 430. Suddenly showing position in pacific ocean. Says Navigation not active. Can not do any thing with GPS/Maps.I did reset command. Took out CG for navigation and put it back. No better.
Any suggestions: |
usually a bad antenna .
navigation s430
Can I buy on net and replace it. or its a tough job
Originally Posted by PB736
(Post 158311)
Cheap Fix for Bad Antenna
I had the same problem. I could not figure out how the antenna connected and apparently someone in the past had the same problem and the antenna was just stuck up there with no connections. It looked like an expensive and hard task to fix it. I went to eBay and bought a cheap antenna that came from China. It was just $12 or so. I plugged it in and put it on my rear fender just running the wire inside the trunk. I plugged the new antenna into the side of the splitter with one wire. I immediately got 7 or 8 satelites. Problem solved and cheap.
If still having problem try disconecting the box in the trunk for a little while then plug it back in, you should see results. The box comes out by pushing in the clip on both side. Good Luck!
