HELP-95 S500-AC doesnot blow cold air
Old Jul 20, 2008 | 02:30 PM
MBS500Boston's Avatar
Default HELP-95 S500-AC doesnot blow cold air
Hi, my car has 123K. AC worked last year till the blower register died. After I replaced the register, heater worked but not the AC. I had it charged to full with 134a, but it still did not work. The AC compressor clutch kicked in for a few seconds then released.When Iturned the AC on, the2 electric fans on the front did not turn either.
Please let me know what was the problem and what I need to do to fix this problem. The local mechanics seems to be baffled by this. I don't have the $$$ for the dealer... Thank you in advance.[8D][8D][8D]
Long
Old Jul 20, 2008 | 04:39 PM
sundaynsonz's Avatar
Default RE: HELP-95 S500-AC doesnot blow cold air
a similar situation happened to me not too long ago...I'd check the regulator if I were you...that did it for me...the part is just $109 @ importec.com and easy to replace...there are installation sites that will walk you through. good luck
Bob
Old Jul 22, 2008 | 12:50 PM
cool's Avatar
check relay located on the fuse box and the relay located underneath the dash.
MondezH
Nov 13, 2014 09:40 PM
Robbie Reilly
Mar 29, 2011 01:25 PM
anand.shetty
Aug 30, 2009 04:01 AM
Longhaily
Aug 2, 2008 07:28 PM
yangxz
Sep 20, 2006 08:20 PM
