Door Panel
Old Jan 30, 2007 | 07:59 PM
VancouverS55's Avatar
Default Door Panel
Can anyone give me info on rear door panel removal? Thanks for your help.
Old Jan 31, 2007 | 12:54 AM
vovpar's Avatar
Default RE: Door Panel
What model Mercedes is this for???
Old Jan 31, 2007 | 08:47 PM
2004 s55
Old Feb 1, 2007 | 04:01 AM
vovpar's Avatar
oh its easy,
1)start off with removing wood trim around the handle, there are screws there
2)remove the plastic piece behind the door pull there is a screw there
3) on the bottom of the armrest there also is a screw, you will see a cap for the hole
4)remove two torx screws around the door lock (plastic cover)
5) start prying up the door at the bottom, there are clips there, then move to the sides
6) pull up the door card after you got everything loose
7) unplug connectors in the back
FOG
Oct 10, 2012 06:08 PM
ash1014
Jan 2, 2006 12:18 AM
vernon97e420
Apr 7, 2005 07:44 PM
GrahamL
May 24, 2004 08:03 AM
rolf
Feb 10, 2004 11:41 PM
