Central Locking Problems Still - 94 S500 Coupe
#11
RE: Central Locking Problems Still - 94 S500 Coupe
I recall a bulletin that the internal hose on the 95? pump was defective and could be replaced, check with your dealer!
The locking pumps that are effected are built as of (Aug94) 140 800 28 48, after chassis #A284726 they would have been modified. It seems they had a defective hose inside causing a leak. the replacement hose is available as Q480 0001. This may or not be your problem, but if you hear the pump running and nothing is activated check that. These pumps also shut down if they can not develop pressure or vacuum.
#12
ORIGINAL: sleepwalker
very true!
the one on the rear left inside the trunk lid is for door closing aid, back-up assist, and trunk lid handle.
under the rear right seat was that PSE pump for central locking.
very true!
carscclass
07-13-2011 10:04 PM
merc500
09-18-2007 08:15 PM
