BLOWER MOTOR
Old May 21, 2007 | 06:15 PM
soaring's Avatar
Default BLOWER MOTOR
I HAVE A 1994 S 320, I KNOW MY BLOWER MOTOR OR THE RESISTOR IS BAD, CAN SOMEONE TELL ME WERE THE BLOWER MOTOR IS LOCATED ON THE CAR?
Old May 21, 2007 | 10:31 PM
sleepwalker's Avatar
Default RE: BLOWER MOTOR
W140?
front right... rear engine compartment. remove that air duct.
Old May 25, 2007 | 09:58 AM
Peter Guenther's Avatar
Open the hood, and locate the oblong piece of plastic which is at the base of the windshield, it has a couple of hoses going to it and four or six phillips head screws. There is also a sensor on the drivers side and two drain hoses. pull the hoses off gently, and remove screws, lift the lid up and away. You will see a filter and the blower motor and regulator are below thaton the fan housing. It is a solid state regulator and it is in the ground side of the motor, no fuses either. The regulator is a common failure, but it also could be a number of things that send it a signal. I would change the filter while in there, but be prepared for sticker shock, so shop on line.
http://catalog.mercedesshop.com/
performance products has pictorials!
xb70valkarye
May 8, 2026 08:01 AM
Ellen Ward
Dec 13, 2006 06:02 PM
necompressor
Jan 18, 2005 06:06 PM
timguildford
Aug 13, 2004 05:30 AM
YuCrew
Apr 14, 2004 02:20 AM
