BLOWER MOTOR
I HAVE A 1994 S 320, I KNOW MY BLOWER MOTOR OR THE RESISTOR IS BAD, CAN SOMEONE TELL ME WERE THE BLOWER MOTOR IS LOCATED ON THE CAR?
RE: BLOWER MOTOR
W140?
front right... rear engine compartment. remove that air duct. |
RE: BLOWER MOTOR
Open the hood, and locate the oblong piece of plastic which is at the base of the windshield, it has a couple of hoses going to it and four or six phillips head screws. There is also a sensor on the drivers side and two drain hoses. pull the hoses off gently, and remove screws, lift the lid up and away. You will see a filter and the blower motor and regulator are below thaton the fan housing. It is a solid state regulator and it is in the ground side of the motor, no fuses either. The regulator is a common failure, but it also could be a number of things that send it a signal. I would change the filter while in there, but be prepared for sticker shock, so shop on line.
http://catalog.mercedesshop.com/ performance products has pictorials! |
