ABS/ARS
Old Jun 1, 2008 | 07:31 PM
RollTide's Avatar
Default ABS/ARS
The ABS/ARS warning lights are lit on my 1994 S500 and i have heard some horror stories with excessive cost involved to solve the problem.Also will this fault make my accelerator pedal stiffer or harder to push? I was told that I do not have the limp home mode but I have noticed that the accel pedal is stiffer than on my other vehicles that are nonMercedes, but the power does not seem to be limited.
When i purchased the car it indicates itwas manufactured 7/95 (inside the drivers door jam), but when i explained to someone that i have an led dtc flasher under my hood they said that dtc flasher was discontinued in 94 and they also said that my car is really a 1994 since it was made 7/95 and it would be a 1995if it was made in 8/95. This did not make much sense to me so is this accurate info?
Old Jun 1, 2008 | 09:30 PM
sleepwalker's Avatar
Default RE: ABS/ARS
california version got dtc flasher
Old Jun 2, 2008 | 05:42 PM
RollTide's Avatar
Default RE: ABS/ARS
The california 1995 has the dtc flasher? So what you are saying is that my car could be a 1995 (california model)?
sladedestiny
Aug 3, 2012 02:55 PM
davidlhorne
Jan 6, 2007 10:40 PM
merckid
Oct 27, 2004 05:43 PM
rb63
May 16, 2004 10:28 PM
Javelin220
Nov 14, 2003 01:44 AM
