'88 300 sel using too much fuel
Old Apr 28, 2005 | 08:56 PM
youngil006's Avatar
Default '88 300 sel using too much fuel
Hi
I have a 1988 300 sel mercedes benz, and it uses way too much fuel. It used to get 400 or so miles to the tank...now it goes about half or less. These are the symptoms:
1-start to engine with no need to push down the gas pedel
2-put in drive, push down gas pedel no respose until i push it down all the way to the floor. then engine revs hi then i get pushed back into my seat, the the car takes off like a bat out of hell, black smoke leaves the pipes. when on high way car runs ok, but has very strong gas smell.
3-when in idel car economy meter stays in the middle, never gets lower until i put it in park.
is there anyone out there with some mercedes knowldege?? my wallet is getting lighter every day paying foe gas.
thanks
*young006
Old Apr 28, 2005 | 11:16 PM
Laterthatsameday's Avatar
Default RE: '88 300 sel using too much fuel
it's most likely your O2 sensor is shorted internally , but it could be internal leakage in the fuel distributor or the EHA is out of spec.
Old Apr 29, 2005 | 12:11 AM
sleepwalker's Avatar
too rich indeed.
takes time to burn the fuel that's why you got delay response on full throttle.
adjust the fuel distributor and check the cause of problem.
Old Apr 29, 2005 | 10:00 AM
youngil006's Avatar
the o2 sensor is fairly new. how do you troubleshoot the fuel distributor?
Old Apr 29, 2005 | 11:46 PM
youngil006's Avatar
is there anyone out there who can help solve this problem step by step??
Old Apr 29, 2005 | 11:58 PM
it is a very long topic to discuss especially if you got no knowledge on CIS-E.
take it to a really good mb mechanic. this will save you time and money.
it can be just a very minor problem.
your car is a mechanical injection system. a special computer is needed to diagnose it (BEAR tester or BOSCH MOT).
chilango
May 2, 2011 01:55 AM
dvoraky
Nov 15, 2007 03:59 PM
sirwhite4
Jan 31, 2007 04:13 AM
BikerDrew
Jan 2, 2007 10:11 PM
Genevieve
Aug 15, 2005 11:57 AM
