600 SEL coolant problem help needed!
Old Jul 23, 2008 | 01:31 PM
spierce88's Avatar
Default 600 SEL coolant problem help needed!
hey everyone,
all of the sudden when i was idling in a driveway the coolant started puring out of the drain at the base of the engine block. At first I though it was a rad hose, or that crazy T shaped plastic part against the firewall everyone has problems with, but ive sourced the leak from the drain hole for the overflow trough at the base of the engine block. when coolant is poured into the system it pours right out of the drain hole! any ideas as to what the problem is? please help if you have a suggestion. thanks!
Old Jul 26, 2008 | 04:13 AM
cool's Avatar
Default RE: 600 SEL coolant problem help needed!
your facts are vague, and you specify further with a simple 1, 2, 3 facts so we may be able to try to address your problem instead of guessing whats your real problem and why the coolants gets out of the drain hose?
harv3317
Jul 31, 2010 03:30 PM
stevemaman
Jun 21, 2009 12:17 PM
JERSEYSURFER
Oct 2, 2008 01:03 PM
hamadl
Dec 27, 2006 04:54 AM
jbsteven
Nov 10, 2004 05:29 AM
