500 SEL, engine dies when trying to move
Old Sep 30, 2006 | 06:53 PM
barehill's Avatar
Default 500 SEL, engine dies when trying to move
Car starts fine and when warm runs fine. But when cold and in gear it wants to die with the slightest accelerator pedal pressure. Car was OK till a mild overheat due to a faulty temp thermostat, subsequently replaced. I got a vacuum diagram and checked all the vacuum hoses and connections. Everything seems in order. Replacing "components" seems like the next step but which one?
Thank you in advance for any assistance.
500 SEL w/ 5L V-8, 126 chasis
Old Sep 30, 2006 | 07:18 PM
mbz300sdl's Avatar
Default RE: 500 SEL, engine dies when trying to move
Replace plugs then wires. If that doesnt fix it please ask again ok.
Old Oct 1, 2006 | 01:15 AM
97dmsrS420's Avatar
Sounds more like an evap problem, or throttle body problem. Need more information as to what his vehicle is doing, like; "What does it do when it's at idle and he presses the accelerator? Is there any backfiring? Or, does it just stall? When pressing the accelerator, does it seem like there's just air, or like there is no fuel pressure?" I'm very curious to know more, if he doesn't mind. It could very well be plugs and wires, but could also be a sensor of a sort. So, I'm not in disagreement with you, it just seems like something's not being said to complete the picture.
Old Oct 1, 2006 | 12:59 PM
mbz300sdl's Avatar
I was basing his explaination on the same syptoms my 560 had then i did that and it has ran fine ever since. But yes i agree it could aslo be a sensor but it never hurts to change the plugs and a first idea (cheap and easy). Also the same thing was happening on my 300sdl and it ended up being the voltage regulator Its next to the fire wall and has a red top with a 10 amp fuse cost me $80 and fixed the problem.
Old Oct 1, 2006 | 09:29 PM
97dmsrS420's Avatar
You're right, leastest is cheapest.
Godfather Benz
Dec 25, 2012 10:44 AM
will4468
Mar 16, 2010 05:02 PM
mercfancy
Jul 4, 2009 01:27 PM
joel_E300
Oct 1, 2006 03:06 PM
s_gilbride
Jan 12, 2006 09:21 PM
