2005 S500 Airmatic Not Operating
Old Mar 6, 2010 | 09:12 AM
UTFan69's Avatar
Unhappy 2005 S500 Airmatic Not Operating
My message center has just started showing "Airmatic - Visit Workshop". I do know that the car will not lift, but I have been measuring the ride height and the level has not changed or lowered. I am assuming that there are no leaks, but that the pump isn't operating. Could it be a fuse, and if so, where do I find a fuse chart? Any suggestions would be greatly appreciated.
Old Mar 7, 2010 | 02:45 PM
MB-TECH-38's Avatar
do you hear pump when you turn car on . fuse is in Right Front Sam [ right side under hood back by firewall it will be a big Maxi Fuse ]
hope this helps
Jerry
Old Mar 8, 2010 | 08:13 AM
UTFan69's Avatar
Default 2005 S500 Airmatic Not Operating
Thanks for your reply. I do not hear the pump. I did find the fuse and sure enough it was blown. I replaced the fuse and the replacement blew out. I am going to try a new relay next before replacing the pump. Does this sound reasonable. The car has not lost any height. I measure the height every day.
Old Mar 11, 2010 | 08:29 PM
MB-TECH-38's Avatar
its going to be the pump, but try relay anyway cause when you get pump you will get Fuse , Relay, & Pump
Jerry
Old Mar 12, 2010 | 07:40 AM
UTFan69's Avatar
Of course, you're right. It is the pump. It looks like water was sucked up into the pump, causing the problem. So, off to a replacement. I appreciate the responses to my message...Thanks.
Old Mar 13, 2010 | 01:12 PM
MB-TECH-38's Avatar
UT,
ur welcome
Jerry
Randy
Apr 19, 2012 09:52 AM
waltersbenz
Jan 9, 2011 11:55 AM
andrew9147
Nov 3, 2010 12:12 AM
UTFan69
Mar 21, 2010 01:43 PM
tweintraub
Apr 13, 2006 08:37 PM
