2000 S500 Intermittent AC
I have had this problem since I bought the car in 2000. It used to only happen once or twice a year, and I could never replicate it for the dealer. Unfortunately, now it is happening once or twice a week. Upon starting the car, it appears from the displays that everything is working properly, but no air is coming out of the vents. The next day, everything will work fine, but a few days later the same problem. I noticed that it used to happen on particularly hot days, now it doesn't seem to matter. Any ideas what the issue might be? I'd really appreciate any ideas to pursue. Thanks.
do you mean that no matter what fan speed you set, it just doesnt blow air at all? is it in AUTO mode? when the system is properly working can you adjust the blower speed and hear and feel fan speed difference? if your in AUTO mode and you start the car, and if its cold outside, the blower will not start blowing air until the engine builds up heat.need more detailon the problem. you could just have a bad blower regulator.
More details
Paul
you might want to check on recalls for the blower motor and harness. back in 2000 or so there was a recall for an updated wire harness and fuse for the blower motor.
also the blower could be seized up from water getting into the blower motor. very very common problem on S class, make sure you water drain cowl is clear of debris. the drain on the passenger side at the fire wall. youll see a grill and look down in there and make sure the drain is not blocked up with dirt and debris. if it does block up, water will flow into the car via the blower motor housing and your interior will get soaked and youll have many more issues.
did you ever find out what the problem was? i am/was having the same issue and now it won't turn on at all. my multi function sensor was bad but i replaced it and it is working now. i have no error codes on the climate control but still no fan. i pulled my blower motor out and tested it separately and it works fine. also tested regulator and that works fine too. i am clueless. any suggestions?
Butters500
02-17-2010 10:38 AM
justaride
07-07-2008 04:55 PM
