Rear control arm upper or wishbone and front tie rod ends
Old Jun 29, 2014 | 12:25 AM
smith007's Avatar
Default Rear control arm upper or wishbone and front tie rod ends
Hi there. w163 Ml 320 2002 manufactured in July of 2001
Anyone kind enough to provide me with a schematic or picture of the rear wheel assembly and front wheel assembly with torque spec would be greatly appreciated.
And any useful tips on how best to ....... even further appreciated
Problem
1. It would appear that upon jacking the rear wheels and grabbing the tire at 12 o' clock position and pushing forward there is play in the upper wishbone in the rear nothing on the 3 and 9 position also no play with crow bar under the rear tire and pushing down on the crowbar in the ball joints.-- so I have to replace the upper wishbone I guess
2. In the front grabbing at 3 and 9 position play in the tie rod ends -- so I guess replace the front tie rod ends
(and nothing at 12 and 6 or crow bar under the tire a pushing down on the crow bar
no play)
To ADD: my discovery of the above was I received a complaint from the driver that at different speeds there would on an occasion be a vibration -- given the above is that a possible cause
Old Jun 29, 2014 | 08:21 PM
chassis221's Avatar
Problem
no play)
Just a heads up, the front outer tie rods are probably seized. And the inner tie rods probably need replacement too.
seadog
Feb 22, 2011 11:13 AM
firstfeather
Feb 8, 2011 09:16 PM
todesto
Aug 30, 2010 02:38 PM
MTech
Mar 11, 2007 08:21 PM
siccmade
Jun 23, 2006 02:47 PM
