ml430 p/s pump leak
Old Jan 2, 2007 | 12:04 AM
KART26WF's Avatar
Default ml430 p/s pump leak
Hello,
Does anyone know if there is a p/s pump rebuild kit available for the 2000 ml430?Dealer or otherwise. If not where is the best place to buy a uesd pump,or is this a bad idea?
Dave
Old Jan 2, 2007 | 02:10 AM
piperca's Avatar
Default RE: ml430 p/s pump leak
What's wrong with the pump? Are you sure it's not a hose?
Old Jan 3, 2007 | 09:24 AM
YuCrew's Avatar
I heard of other owners simply replacing the gasket betweeen the pump and the reservoir and leadproblem solved.
Old Jan 10, 2007 | 01:22 AM
MBZTech's Avatar
Its usually the o-ring between the pump and reservior that leaks. I did have one the other day that did have a leaking pump. The dealer doesnt sell a rebuild kit. I think the pump was around $700
Old Feb 20, 2007 | 12:50 AM
husa4342's Avatar
I had problems with a couple of the non presurised hoses on our ml430, then finally found another leak that was bad. there is a resevour with 2 round flat bolts look like 1" washers with a strange head on them, they were both loose and leakin fluid. it is located behind the axel on driver side on the opposite side that the hoses bolt on to. not sure what it is, but is sure cost me alot of fluid.
slyc230
Apr 19, 2024 10:10 AM
orcldba8
Sep 11, 2013 11:06 AM
mearl71
Sep 14, 2008 07:54 AM
videoman
Mar 26, 2007 07:59 PM
Bigeasyherb
Jan 28, 2005 12:57 AM
