ML430 Driverside window
The switch is bad, I had the same thing happen to me last winter. The contacts on the switch are pushed down and wont make contact. I googled the window switch repair it told me stepby step what to do. That switch contains all four window switches so its pretty expensive (250.00)
ORIGINAL: btelin
Driver side window will not close. It will power down but not up.
Where do I start?
Where do I start?
I've done it myself and it's farely simple:
http://www.grill.org/rodney/mclass/mlswitch/index.html
Good Luck
Hello,
I am having a problem with the switches. I followed the directions you put out but; I am having a problem getting the black plastis switch covers for the rear window defrost and the door locks. When I put them back on they do not move enough to activate the mechanisms under them. They will only go on one way so it is not like I am putting themon backwards. Any thoughts? Thank you.
slyc230
Apr 19, 2024 10:10 AM
