Driverside rear door wont unlock
Old Mar 15, 2010 | 06:05 PM
TX E430's Avatar
Default Driverside rear door wont unlock
I have a 2001 E430 and the driverside rear door won't unlock with electric locks. These locks work slower they dont just pop up like on most domestic so I think it may work on some type of vacuum. Does anyone know what might be the issue?
Old Mar 15, 2010 | 07:24 PM
Scuddog's Avatar
Wink Common issue
Tex,
I have the same problem on my pass rear side. I've been living with it for about 1+ years now. It will lock but won't unlock. My indie mechanic checked it out and identified good vacuum but a bad lock actuator. Approx $260 to fix. I can live with that. Pull out your rear seat and put the remote in your hands. Go to a quiet area first, then cycle the locks and listen for a hissing sound or whatever. If you can't identify the issue from a leaking hose or whatever near the battery (mess of yellow cables going into a box is your vacuum box), then you may have to make a decision... get it fixed by your mechanic or live with it. Good luck.
mjnt
Jul 6, 2015 06:30 AM
Mr.745
Dec 31, 2011 10:40 PM
btelin
Jan 26, 2008 02:07 PM
ptldMerc
Sep 22, 2007 04:03 PM
legenesepimp
Nov 2, 2005 05:04 PM
