ML HAS MECHANICAL PROBLEMS...HELP!
When I first start the car, it will start up and run rough...If Ipump the acceletator it will reach 3-4 rpm's and then sputtering as if there is trash in the fuel line. If I put it in gear and let it idle, it moves slowly. If I try to give it gas, itdoes not move, almost like it's starvin for gas. After it idles for approx. 5 mins it will shut off by itself. I pulled the fuel line at the injectors and itis not pumping any gas. It seems to start pumping gas if I let it sit for an hour or so. Can anyone please help me. It has 142,000 miles on it now. Cananyone also tell me how to drop the gas tank?
if your looking for the fuel units you dont have to remove the tank at all. they are under the 2nd row of seats. fuel filter and fuel regulator are on frame on inside of left rear tire. that could be your problem they are notorious for that.
tropics
Mar 30, 2008 08:36 PM
