Engine Coolant Leak
Old Dec 5, 2007 | 09:14 PM
67tree's Avatar
Default Engine Coolant Leak
ML320 2002... outsidetemperature dropped this past week to -15degC... suddenly started seeing pools of coolant under the front bumper... I lay under the front end and noticed what appears to be a leak around the radiator hose... or the coolant could be running down teh radiator (hole) and pooling on this clamp (big problem) or maybe just the clamp/hose assembly is no longer holding... is it relatively easy to pull this hose off and install a new one (purchase from an auto parts store)??? or is my problem likely bigger than I appreciate?
Thanks.
Old Dec 5, 2007 | 09:15 PM
67tree's Avatar
Default RE: Engine Coolant Leak
P.S... Would this be covered under extended warranty? I purchased this with the vehicle..
JERSEYSURFER
Oct 2, 2008 01:03 PM
hennesseystealth
Mar 4, 2007 02:13 PM
Randy
Mar 15, 2004 12:36 AM
rostov
Jan 8, 2004 08:19 PM
teeman
Dec 11, 2003 09:34 AM
