2011 ML350 Nosie in right side of wheel well
Old May 20, 2024 | 09:20 AM
KingColty's Avatar
Default 2011 ML350 Nosie in right side of wheel well
Hey, so i just got this ML350 month ago. when I bought it i could hear a noise in right wheel well, I thought it should be a easy fix, thought it was sway bar link, I bought the ML350 with 210KM on it. So I decided to change almost everything that has bushings and ball joints. So I ended up changing yesterday lower ball joint, Inner tie rod, which when I took the old one out it had a lot of play in it, so I was like maybe that was the noise I'm hearing. also changed the Outer tie rod, the swag bar link, upper control arm and the air strut all on the right side. took it for a ride after i did all the work and i was excited thought for sure it would be fixed. still makes the noise when im going down a bump road and then when im stop and just taking off i hear the same noise of clunk but all the noises sounds like its in the right side and if your sitting on that side it feels like you can feel it on the bumps as well. Here is two videos of the sounds
Let me know what you guys think! THANK YOU!
AWOYNO
Feb 6, 2016 08:24 PM
coreyt
Jan 23, 2013 07:17 AM
anke_nielsen@yahoo.com
Jan 31, 2012 12:00 AM
04mbs430
Aug 17, 2009 11:16 PM
