Popping noise
i hear this popping noise everytime i turn the steering left or right at standstill, i took it to the dealer they said( after stupidly replacing everything else like upper balljoints, caster bushing etc) that noise is normal in the e class. Does anyone know about this sound , a solution?
thanks.
thanks.
it sounds like something underneath is shifting when i turn the wheel left or right, i feel it mostly under my feet area, slight rattling noise when i drive slow.
could be the lower control arm, where the bottom of the strut meets the lower control arm. or the lower ball joint or the upper control arm ball joint. also sway bar bushings. they all have the same sort of sound.
freshmo55
Feb 24, 2008 08:44 PM
