2007 ML 350 speedometer not working
Old Dec 3, 2019 | 07:56 PM
milicev's Avatar
Default 2007 ML 350 speedometer not working
2007ml350 speedometer doesnt work. little background i got this car with smashed front end. I replaced bumper, hood, front clip with used. before i replaced anything the car still drove and everything worked. the two sensors that go in the front clip next to headlights im not sure if i used the ones i had or ones off of the used clip. i get codes of my generic scanner (0925 CAN signal ' Vehicle speed at front axle' from control unit Traction systems is implausible. (p2158)
ALSO No CAN message was received from control unit Traction systems.
ALSO C121 No CAN message was received from control unit N47-5(ESP and BAS control module)(171/203/209) or from control unit N47-5(ESP control unit)(164/219/251/216/221) or from control unit N47-5(ESP,SPS [PML] and BAS control unit(211/215/220/230) or from control unit Brake system ALSO D139 No CAN message was received from control unit N80(SCM[MRM] control unit)
ALSO 062F Component Y3/8n4(Fully integrated transmission control (VGS) control unit) is defective
Would me placing the wrong sensors back in place cause all of this. I replaced front speed sensors in axles that didnt fix anything.
I cant seem to attach the pics but numbers on sensors are:
0038202926
965 031106
132 403030
Q01
Could this be a relay or does anyone know where to begin?
thanks
Old Apr 10, 2020 | 10:42 AM
RomanVR's Avatar
Hi. Did you fix your issue? I'm having same thing.
Old Apr 10, 2020 | 02:03 PM
milicev's Avatar
Mine ended up being abs pump. Got used one on eBay for 60 and got lucky didn’t need to be programmed
danrob
Feb 15, 2011 08:31 PM
GDRIII
Mar 20, 2009 09:20 PM
mbhackie
Aug 4, 2008 09:11 PM
limey300sl
Jun 30, 2006 10:59 AM
k_alavi
May 25, 2005 11:06 PM
