2001 ML320 CD CHANGER WILL NOT EJECT MAGAZINE-RADIO CONSOLE DOESN'T RECOGNIZE CHANGER
Old Mar 4, 2011 | 08:43 AM
  #11
1luckywife's Avatar
macfish... did u find an answer to the problem?
Old Mar 12, 2011 | 03:45 PM
  #12
me61ic's Avatar
Originally Posted by mackfisherman2
I have the same issue as several posters. Control system does not recognize that the cd magazine of 6 cds is loaded and it will not eject. There must be a simpler solution than replacing the whole unit. Person that posts the solution I will send $50 to (promise)!!!!!
No need to send anything...
http://blogs.sun.com/miko/entry/cd_changer_repair
Old Mar 14, 2011 | 03:56 PM
  #13
1luckywife's Avatar
thanks so much me61
will do this week or next and report back how it goes. thanks again for the response
Old Jul 2, 2011 | 08:16 PM
  #14
Grasu200's Avatar
Default No Changer
I did the repair - before finding this posting - Miko describes the reapir to last detail. Unfortunately for me, the mechanical problem being fixed, I am no faced with the "No Changer"message.
Anybody any suggestions?
Thanke you!
Old Jul 7, 2011 | 09:23 PM
  #15
CyclingResponder's Avatar
Default I solved the problem... kinda...
I own a 2002 ML 320 and after parking and driving out, I noticed the CD changer stopped working. So I came home and found this forum.
After trying to pull the CD changer out, I accidentally smacked the CD changed with my knee... Once that happened, a whirling sound happened and the cartridge popped right out! I put it back in and tried to listen to the CDs and it worked! I went back, opened it and tried ejecting the cartridge and it seems everything worked....
So I'd suggest (if you want) to give it a good smack on the side and see if it allows it to pop up.
Old Dec 5, 2011 | 06:58 PM
  #16
RRettke's Avatar
Default Possible reason for cartridge not ejecting
I had a similar problem on my 2000 S500. This post is only in regards to the inability to eject the magazine. My system is a ten disk changer so this may not apply.
I too had a lot of "CD's" that I had burned and frequently I could not get the magazine to eject (other than through dogged persistence). Eventually I started taking a very close look at what was happening. I found that tolerances in the CD changer were so close that the sticky labels that I had on my CD's (Full CD size inkjet printed label) were getting hung up in the changer. I stopped using the labels (just wrote on the CD's with a sharpie) and never again had a magazine ejection problem
Hope that helps.
Old Dec 15, 2012 | 04:23 PM
  #17
princeggg's Avatar
Thumbs up "No Changer" issue fixed
They prove it every time you call them don't they "Dealers are stealers". You don't need to spend even a single penny to fix this problem. Its probably a CD that has got stuck in the changer for one of the many reasons. Like one post suggested, just give your CD changer a good smack or two and it will start working again. It worked for me!!!
Old Nov 1, 2013 | 03:23 PM
  #18
nwdiva's Avatar
Default Cassettte retrieved!
Well, after posting about the same problem, I then went and searched the board... A combo of 'tough love' and activating the release switch with a thin piece of sturdy plastic while pushing the eject button gave me what I wanted: The cassette from my CLK500. After I remove the burned disk (which come to find the changer does not like the flavor of) I'll try it again! Thank you all!!
Old Jan 15, 2022 | 07:27 PM
  #19
nwshell's Avatar
Default Fixed link
Originally Posted by me61ic
New link: https://mikofang.blogspot.com/2010/0...er-repair.html
Old Jan 15, 2022 | 07:28 PM
  #20
nwshell's Avatar
MyNewE320
Aug 29, 2025 04:59 PM
mackfisherman2
Feb 9, 2011 08:13 PM
Jalife
Feb 27, 2010 11:14 AM
hally
Jul 12, 2009 07:39 AM
slpman
Feb 27, 2006 12:04 AM
