2000 ML430 AC not working
Old Jul 13, 2009 | 02:43 PM
skasu123's Avatar
Default 2000 ML430 AC not working
Any thoughts folks? The air flows in fine but is not cold.
Old Jul 14, 2009 | 12:24 PM
mbenz80's Avatar
Low on refrigerant? Turn it on and check system pressures to see what is going on.
Old Jul 15, 2009 | 12:54 AM
rdarvish's Avatar
Default A/C blowing warm Air
I have the same problem on my 98 E320. the clutch kicks in but it does not cool. I checked the pressure. the low pressure is about 33 and the high presure is 100 PSI(too low). I tried to add more refigirant but the system won't suck it in.
I appreciate any help.
Old Jul 15, 2009 | 08:11 AM
mbenz80's Avatar
Sometimes you have to wait a while for the suction affect and your refrigerant can have to be higher and upside down to get the liquid flow into your A/C system. Add little by little at a time to suction side (thicker pipe) to avoid overcharge and check each time with your pressure gauge.
Old Jul 15, 2009 | 09:53 AM
skasu123's Avatar
How to check pressure? Is there a way to check refrigent level?
Old Jul 15, 2009 | 03:52 PM
mbenz80's Avatar
The correct refrigerant valume will build correct pressure in your system. The best way is to recover all the refrigerant from your system and recharge it with specified waight on the label in engine compartment. You can get low side pressure gauge at auto parts store or walmart, plug it into your A/C port and it will show you if you need more refrigerant/pressure. Comes with (easy to use) instructions.
Old Jul 15, 2009 | 06:37 PM
rdarvish's Avatar
My high pressure in my 98 e320 reads 100 PSI which is very low but the low pressure reads 33 PSI (normal). Howeve, it blows warm air. any body knows what causes the low high pressure reading and the warm air?
Preciate the help
slyc230
Apr 19, 2024 10:10 AM
patricknif
Mar 4, 2012 06:38 AM
Paul Dalton
Feb 7, 2012 02:37 PM
athenshome
Dec 10, 2009 09:59 AM
polo1ral
Aug 24, 2007 09:52 PM
