ML430 Horn Not Working??
Old Dec 9, 2009 | 07:51 PM
athenshome's Avatar
Default ML430 Horn Not Working??
I have a 1999 ML430 and recently changed out my left headlight, but now my horn is not working. I have not done anything else under the hood and all the fuses are good. The horn just seems to have stopped working. I'm not sure if I could have done something during the headlight switch to disable it or what.
Does anyone have any suggestions on a possible solution to getting the horn working again, or have some insight on what may have gone wrong? Thanks in advance!
Old Dec 10, 2009 | 09:30 AM
mbenz80's Avatar
There is not much to horns and their operation.
I would check for horn relay (stuck in open position), check with light bulb or multimeter if you getting voltage at the horns, or if you have voltage comming from steering wheel switch to the coil of horn relay. It could be broken wire in the steering column mechanizm. Try to turn your steering wheel while pushing the horn button to see if it has any effect on it.
Bernard
Old Dec 10, 2009 | 09:59 AM
chassis221's Avatar
there are 2 horns, 1 on either side of the car behind the bumper..kind of below the headlights.
NotesDOGG
May 8, 2010 04:22 AM
lydiah
Mar 18, 2010 07:11 PM
avcomm22
May 12, 2008 07:58 PM
avcomm22
Mar 14, 2008 08:13 PM
allanb888
Aug 1, 2005 12:53 PM
