Wiper
Wiper
<SPAN style="FONT-SIZE: 8.5pt; FONT-FAMILY: Verdana; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">Have a 95 e320 with 126k, runs great. Wiper is off, but it intermittently gives a swipe or two across the windshield. Any idea?</SPAN>
Wiper
that's an odd problem, it sounds like you have an intermittent short in the wiper stalk or a relay going bad. I would check the relay first and then go from there. It is relay H located in the relay box on the drivers side behind your fuse box, under the hood.
Wiper
<TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNABLE="on">
<T>
<TR height="100%" UNABLE="on" width="100%">
<TD id=HB_Focus_Element vAlign=top width="100%" background=" height=250 UNABLE="off">
<FONT size=1>I´ve had a similar problem. The reason was bad grounding. </FONT><FONT size=1>There is a grounding point under each headlight, where a number of cables are grounded toa bolt , take it apart and clean it, maybe this will do the trick.</FONT></P>
<FONT size=1>Good Luck!</FONT></P>
<FONT size=1></FONT></P></TD></TR>
<TR UNABLE="on" hb_tag="1">
<TD style="FONT-SIZE: 1pt" height=1 UNABLE="on">
<DIV id=hotbar_promo></DIV></TD></TR></T></TABLE>
<T>
Wiper
Can someone help me </P>
i got a 300 e 1991 benz 300 kilometers </P>
i'm in montreal and at times in winter it gets very cold,what happens is when the temperture gets like -20 celsius and more i have no problem to start it in the morning but i leave with it do a few miles and the car just shuts down on me at the first stop i'll doand there no way i could get it to sart any more,it will crank but won't start I'll wait 20 minutes try again and it will start this occurs only extreme cold tempertures in the summer or warmer winter temperture it doesn't do this problem i would appreciate if someone can help to this.</P>
what I think the possibilities of the problem are</P>
a coyle problem</P>
the gas pump -relay- resistance</P>
the idel controll valve box</P>
</P>
