Water Pump Question
Old Dec 12, 2006 | 12:35 AM
jimkari's Avatar
Default Water Pump Question
I own a 87 300E (gas). This weekend it started to leak coolant fairly constantly (steady drips, only when the engine is running). It was coming from the driver's side of the engine up toward the front. The best I can tell it is the water pump. As I was removing the pump I notices there is a hole in the block just down and to the left of the lower left water pump mounting bolt. Does anyone know if there is supposed to be a bolt in this hole?
Thanks,
Jim
Old Dec 12, 2006 | 02:51 AM
vytamenc's Avatar
Default RE: Water Pump Question
yes it is normal
Old Dec 13, 2006 | 12:19 AM
jimkari's Avatar
Thanks for the quick reply. If you don't mind I have one additional question. I just picked up a replacement water pump from Auto Zone (Duralast new unit). It has an extra heater pipe fitting located on the thermostat neck. My car only has one heater pipe connection facing the engine block. Does anyone know if there is a plug that is supposed to go in this additional hole? I'm assuming the pump is universal for several years and thus has this extra fitting. However my pump did not come with a plug. Has anyone run into this before?
Thanks again,
Jim
Old Dec 14, 2006 | 02:43 AM
vytamenc's Avatar
yup those are generic pumps find a plug for the hole. and yes they are metric threads
tamvette68
Dec 11, 2010 02:46 PM
geminiys
Jun 18, 2010 01:04 PM
YuCrew
Jan 3, 2007 09:25 AM
kanio
Sep 15, 2006 04:25 PM
champion
Mar 11, 2006 02:49 PM
