vibration when in drive
Old May 20, 2006 | 11:37 PM
MBMEX's Avatar
Default vibration when in drive
my 1998 e320 always vibrates when the car is in a stop and the transmission is in drive, now my 2000 e320 is also doing the same very thing. what could it be, it has to be something related to the transmission because when i put the stick in the parking position the vibration stops.
Old May 20, 2006 | 11:43 PM
Battlecat714's Avatar
Default RE: vibration when in drive
sounds like motor mounts homie.
Old May 20, 2006 | 11:49 PM
MBMEX's Avatar
how many are they and where are located? could i buy them in a dealer and do the repair at another workshop? or you recomend me go to the dealer?
Old May 21, 2006 | 03:59 AM
snanceki's Avatar
Could be idle speed related. What is the idle speed in Park and in D (presumably when hot)
If different, does the vibration go if you increase idle speed in D up to the same speed as it runs at in P? TAKE CARE! CAR MAY START TO MOVE FORWARD IF YOU INCREASE REVS TOO MUCH.
Could be a misfire at low revs. Any fault codes. (Need an OBD reader.
Stuart
Old May 21, 2006 | 06:06 PM
I'd say dealer because usually, aftermarket mounts tend to crack a lot faster and are of poorer quality. There are two I think.
Old Sep 26, 2006 | 10:41 AM
nkpnkp's Avatar
I agree with Battlecat get yourself OE only. THey cost more but last longer. Not an easy job have your mechanic do it. By the ways there are 3 of those mount. OFten overlook is transmission mount.
Mr.47
Dec 30, 2006 09:00 PM
tonytax
Sep 25, 2006 10:37 AM
AMGDragon
Jun 29, 2005 03:40 AM
neobopr
Jan 5, 2005 02:16 PM
