Drive shaft vibration
Old Sep 9, 2006 | 12:15 PM
tonytax's Avatar
Default Drive shaft vibration
I have recently replaced the front donut on the drive shaft of my E200, ever since ive had vibration in second ant third gear can anyone help me?
Old Sep 11, 2006 | 07:48 PM
97dmsrS420's Avatar
Default RE: Drive shaft vibration
Question is, what made you replace the donut to begin with? You may have had a driveshaft problem all along. If that be the case, it is what will have to be replaced.
Old Sep 13, 2006 | 02:22 AM
SL600_Cruzin's Avatar
I agree with 97dmsrS420,
A bit more info on your problem would certainly help us to help you.
Old Sep 13, 2006 | 06:10 PM
tonytax's Avatar
I got it sorted, the problem was the shaft bearing.Thanks for replying. tonytax.
Old Sep 24, 2006 | 10:20 PM
88300e's Avatar
i had problem with my drive shaft when i shift in in any gear expecialy R u can hear it hit hard metal to metal and when it shift down u can hear it hit and the drive shaft was very loose so that was bad i took it to mechanic he said the u know that rubber o ring that conneced to drive shaft it was needed to be replaced frong and back and the drive shaft needed to be tighted so i did that for 312$ and now its so smooth i think 312$ was good deal bc both o rings i looked in auto zone checkers etc was 200$
Old Sep 25, 2006 | 10:37 AM
nkpnkp's Avatar
I had similar problems few months ago. I end up have my mechanic replace Flex Disc front and back. Drive shaft bushing and Drive shaft rebalnce. Parts and labor not cheap but it was covered under my warranty. I just have to pay a small co payment.
davecut
Mar 15, 2008 02:04 PM
davecut
Mar 15, 2008 02:03 PM
mattc230
Aug 16, 2006 04:10 AM
FALCON900
Oct 3, 2004 01:34 PM
