Turn signal/CC stalk loose
Old May 26, 2006 | 12:12 AM
  #11
uberwgn's Avatar
Default RE: Turn signal/CC stalk loose
Thanks, yeah, access to the screw would be possible if you drilled a hole thru the plastic collar....that would have been much easier.
I'll look at our '02 to see if it has an access port.
I have many more pictures which I will post when I have a chance.
Old May 26, 2006 | 11:29 AM
  #12
uberwgn's Avatar
The '02 car has no access port.
Old Jun 1, 2006 | 01:48 PM
  #13
jeremy156's Avatar
So, are you suggesting there might be no need to remove the steering wheel, but instead (carefully) drill a hole in the bottom of the housing to gain access to the bolt(s) we need to tighten?
Old Jun 1, 2006 | 11:45 PM
  #14
uberwgn's Avatar
A purist would never drill holes in his Mercedes Benz.
It might be difficult to drill the hole in the correct location...
marky65
Jul 1, 2014 09:23 AM
bluenose
Feb 14, 2010 10:19 AM
tessshoup
Sep 6, 2008 08:46 PM
ML320white
Nov 16, 2007 05:02 PM
PIMPYD
Feb 8, 2004 11:29 PM
