headrest drive
my 1995 e320 had the same problem. I could hear the motor working, but no movement. Had to remove the seat-back...two screws at the base of the back, then the panel has to be pried from the upholstery. Not as difficult as it sounds. I my case the plastic guide for the gear that runs the rod up and down had broken. A hose clamp did the trick, and it's been working just dandy ever since. Good luck!
AMGDragon
Jun 29, 2005 03:40 AM
