sunroof cables 99 E320
Old May 30, 2007 | 07:30 PM
jasmine2's Avatar
Default sunroof cables 99 E320
would appreciate some advice.I have the headliner and sunroof assembly out of the car.Need to know if there is any special way to install new cables both Right and left.or anything else to look for.thank you
Old May 30, 2007 | 08:12 PM
chassis221's Avatar
Default RE: sunroof cables 99 E320
Hello actually its pretty simple. you must remove the overhead control panel, remove the sunroof motor and then pull out cables. install same way. I forgot you must remove the glass from the roof and then undo the cables from the sunroof track. a little hard to explain with just text. you will install the new cables from the sunroof then feed to the sunroof motor.
Old May 30, 2007 | 08:50 PM
jasmine2's Avatar
THANK YOU DO YOU KNOW IF THE CABLES OR ROOF HAVE TO BE IN A CERTAIN POSITION BEFORE
INSTALLING THE MOTORSO THAT IT OPERATES PROPERLY.
Old May 30, 2007 | 10:21 PM
raymond~'s Avatar
in case any of this helps...
http://w210.pietrzyk.net/disassembly_77glasspanel.htm
Old May 30, 2007 | 10:54 PM
chassis221's Avatar
im not exactly sure on the position but i can find out.look at the new cable so you can identify where the roof needs to be to acess the screws for the cable. i think tilted or the vent position. after you take the glass out you will get a good view of the operation and how to access the cables on both sides. you can mark the old cable when you take out the motor. you will see 2 cables just mark them with white out so you can see how far from the end of the cablesyou are. then mark the new cables. then install them.
Old May 30, 2007 | 10:59 PM
fad446's Avatar
Hi Raymond,
That video was very helpfull to me........removing my sunroof. I was wondering if you might know where I can get that YELLOW BUSHING discussed in the video. The bushing is part of the "tilt" mechanism. The dealer told that the bushing does not come w/ the tilt block. I need to purchase that yellow bushing seperately.
Old May 31, 2007 | 02:22 AM
raymond~'s Avatar
which video mentioned it? i dont want to watch them all
Old May 31, 2007 | 06:45 AM
jasmine2's Avatar
Raymond thank you this was a tremendous help.
Old May 31, 2007 | 11:58 PM
  #9
fad446's Avatar
Step 4 of the same link you gave Jasmine2
Old Jun 1, 2007 | 12:51 AM
  #10
raymond~'s Avatar
ahh...i see it now. according the Russian parts diagram site, it does seem to validate that which was said by the dealer, ie not separate part numbered and orderable by itself.
http://www.detali.ru/cat/oem_mb0.asp?TP=1
(bookmark the above link - great info ! if you have Adobe Acrobat, you can save all w210
to your PC for future ref in case the site shuts down)
this is the pic i'm referring to which seems to confirm this....parts 80 and 60. what do you think?
CollectiveSoul
Feb 18, 2007 03:54 PM
meowcat
Feb 6, 2006 09:31 PM
qha000
Nov 27, 2005 01:21 PM
benztech75
Aug 30, 2005 07:42 PM
