power seat movement balky/fails
Old May 29, 2006 | 07:10 PM
davesbenz's Avatar
Default power seat movement balky/fails
My wife's 1987 300E passenger seat has started to baik and fail to respond in some directions using the door mounted controls.
Is this problem most likely in the switch mechanism, relays, or in the motors themselves?
We have owned this MB since new and have been amazed at its reliability, particularly the interior controls and switches.
Any suggestions or links to wiring diagrams will be most welcome.
Old May 29, 2006 | 07:47 PM
rjburfoot's Avatar
Default RE: power seat movement balky/fails
I'm afraid I can't supply any diagrams etc, but it's very likely to be the control switch on the seat. Electric seat / mirror / window switches tend not to be easy to open and fix. I usually buy a working one from a specialist breakers and replace it.
The intermittent nature of the fault suggests it's not the motors themselves.
Good luck!
Old May 31, 2006 | 02:11 AM
touring's Avatar
Check to see if you have power at the connector between the wiring harness and the seat. My '95 had a similar problem and it turned out to be a dirty connection. The front of the seat would raise and lower, but the back was stuck down. Use a volt meter while activating the switch...this will tell if the switch is at fault. You can also identify which wire goes to which motor in this way.
Old Jul 1, 2006 | 11:05 PM
brian576's Avatar
when was the last time fuses were replaced?
Little-Acorn
Apr 14, 2014 06:49 PM
I love the PCH
Sep 28, 2010 12:40 PM
I love the PCH
Sep 8, 2010 11:42 AM
mrbadx19
Jan 7, 2008 06:08 PM
dvoraky
Nov 15, 2007 03:59 PM
