oil change
The drain plug is on the left side of the lower oil pan. Remove the rear lower engine cover. If you remove it to drain the oil you need to make a splash guard of some sort or oil will fill the subframe area. It will make a big mess and take forever to get the oil to stop dripping out!
floresadolfo1
Jan 26, 2007 04:15 PM
