oil change
Where is the oil drain plug on a 2008 E350?
The drain plug is on the left side of the lower oil pan. Remove the rear lower engine cover. If you remove it to drain the oil you need to make a splash guard of some sort or oil will fill the subframe area. It will make a big mess and take forever to get the oil to stop dripping out!
how do you change the trunk light inside the trunk on the sides of a 2008 e350
