No rear brakes on 220TE
Old May 9, 2006 | 08:03 AM
ensten's Avatar
Default No rear brakes on 220TE
I have a MB 220TE and now I have problems with no rear brakes. I have tested to change the main brake cylinder (not sure about the correct english name). I have also tested if there is a stop in the pipes but with no result. Does anyone have any idea?
Patrick
<EDIT: It is a -93, W124>
Old May 9, 2006 | 09:42 AM
sleepwalker's Avatar
Default RE: No rear brakes on 220TE
the brake system on your car is quite simple and straightforward.
you may start tracing for pressure starting from the master cylinder. use your finger to stop the pressure while somebody steps on the pedal.
then follow the line doing the same thing... ABS hydraulic unit, and before it enters the caliper.
bleed it well.
CLK500KID
Dec 3, 2007 08:41 PM
timguildford
Sep 5, 2007 07:01 AM
mattc230
Nov 19, 2005 01:36 AM
jfclague
Aug 30, 2005 09:57 PM
soaring
Apr 6, 2004 10:58 PM
