idle - 1990 300TE
Old May 30, 2008 | 10:47 PM
cliff's Avatar
Default idle - 1990 300TE
any advise on a stumbling idle after the engine warms up? I can reproduce this at will. engine starts fine and is okuntil it starts to warm up and then gets progressively worse with temp until it is virtually stalling and then bumping back to idle with associated vibration as though it's missing. happens everytime, and then may be difficult to restart if warmed up and restarted. i have cleaned the idle valve out, cleaned all electrical connections (coil, accelswitch,etc) and replaced a couple of suspect vacumn lines...still the same..02 sensor maybe? or could the idle control valve be shot? i hope not, those things are expensive but easy to replace...any back yard mechanic way to verify that the valve is functioning? thanks
cliff
Jun 23, 2008 08:40 PM
thealmighty24
May 11, 2008 07:49 AM
honkytonkhank
Dec 5, 2006 02:02 AM
Robin
Mar 25, 2006 05:09 PM
doctortr6
Feb 22, 2006 08:52 PM
