How to get into the E350 air filter??
Old Sep 16, 2008 | 09:49 PM
sea_bird200's Avatar
Default How to get into the E350 air filter??
Does anyone know how to remove the engine cover so I can get access to the 2006 E350 air filters ??? I was able to remove the front cover but not the rear that sits on top of the air filters[:@]
Old Sep 17, 2008 | 09:28 AM
asica's Avatar
Default RE: How to get into the E350 air filter??
HI,
If I recall, you simply remove the engine cover, flip it over and there are 4 screws per filter...
Old Sep 17, 2008 | 01:41 PM
My question is: how do you remove the rear engine cover ??? there is a big metal clip toward the rear... anything else do I have to remove prior to lift up the rear cover ??
Old Sep 19, 2008 | 03:24 PM
srivera2's Avatar
I have a 07 E350. I don't know if the engine covers are the same. Probably are.
In my car after removing the front cover, there are 3 clipsin the main cover
one in the left , close to a small hose (you have to remove also) and two in
the back. To remove , you have to push the cover up from the clips. The same
with the one on left front. Remember to disconect the hose (small) and the two
hoses on each side. Once you pull thecover, there aretwo filters, you can clean
or replace depending on the miles andfilters condition.
If you need some photos , let me know I can take these and send to you.
good luck!
Oh!!.. I forgot to mention that you have to push the metal clip back to free the cover.
Sergio
Old Sep 19, 2008 | 06:56 PM
ohlord's Avatar
Banned
OEM at www.autohausaz.com
do not use k/n
ohlord
StickyBenz
Feb 1, 2012 06:24 PM
parasuco
Mar 13, 2009 02:21 PM
sea_bird200
Sep 15, 2008 07:18 PM
MBENZ300SD
Dec 31, 2007 08:33 PM
engprosinc
Oct 10, 2007 06:38 PM
