Drive Staft u-joint removal??
Old Sep 14, 2008 | 03:44 PM
jimkari's Avatar
Default Drive Staft u-joint removal??
I have a 87 300E. I need to replace the u-joint on the drive shaft. Does anyone know if the u-joint caps are just pressed into the drive shaft yoke? It looks like there are some indents in the yoke that hold the u-joint caps in place. Also does anyone know what size Torx is used to remove the half shaft bolt at the differential? I'm assuming they are Torx type bolts. Finally does anyone know what size socket is used to remove the pinion shaft - drive shaft mount?
As you might have guessed, I need to do a little work on the drive shaft and the differential is leaking fluid. I thought it makes sense to address it all at once.
Thanks,
Jim
Old Sep 19, 2008 | 10:29 PM
MBZTech's Avatar
Default RE: Drive Staft u-joint removal??
There are no U-Joints. There flex Joints.
glennnall
Jul 13, 2010 09:44 PM
cartrax2004
Jul 4, 2009 09:34 PM
mattc230
Aug 16, 2006 04:10 AM
AMGDragon
Jun 29, 2005 03:40 AM
Walter
Aug 26, 2004 12:17 AM
