How to connect again the power antenna? and Speakers question.
Old Feb 18, 2007 | 08:47 AM
CollectiveSoul's Avatar
Default How to connect again the power antenna? and Speakers question.
Hi, sorry for my bad english.
I just bought a Mercedes E420 1994. The last owner used a satellite radio in the car and disconnected the power antenna of the car to avoid noise or something like that. When I turn on the radio the antenna does not move at all. I want to use the antenna again and I checked in the trunk and all the cables looksOk in the right place. Maybe was disconnected on the radio? Do you know the easy way to remove the radio (cassette player) without damage the wood console?
Also I want to change the front speakers. (the left one soundswith a strange vibrationor something)Do you know if I will find the same size in the sound stores? I don't want to modify anything in the car.
Thanks!!
Old Feb 18, 2007 | 02:34 PM
mbz300sdl's Avatar
Default RE: How to connect again the power antenna? and Speakers question.
Do you have an aftermarket cassestte player in the car?
If it is a aftermarket cassesste there will be a Blue or Blue with white stripe wire that needs to be connected to the power antenna wire not a hard fix at all.
If it is stock i am not sure cause i have never been lucky enough to get a Mercedes soon enough b4 someone else has cut into the factory harness. My guess would be that it will be obvious that a wire will be disconnected and will either need to be spliced back together or plugged back in.
Also yes you can find speakers at an Audio or a Best Buy or Circuit City that will fit.
Old Feb 18, 2007 | 02:47 PM
Yes, I have the stock player. But even I need to know how to remove the player to check the antenna connector.
Old Feb 18, 2007 | 05:05 PM
jackd's Avatar
To check connections to the readio, you need to take it out;
http://www.mercedesshop.com/Wikka/W124Stereo
Old Feb 19, 2007 | 03:15 AM
Thanks!!! thats what I need!!!
you89
Nov 25, 2006 04:05 AM
migabc
Jul 6, 2006 11:10 PM
wawago
Jun 8, 2006 01:45 AM
deluxepaint
Feb 20, 2006 01:48 PM
