IT'S FIXED !!! HELP : Engine barely runs ! (C240) after battery dis-connect
Old Feb 19, 2006 | 10:31 AM
MwCH's Avatar
Default IT'S FIXED !!! HELP : Engine barely runs ! (C240) after battery dis-connect
Well, I dis-connected the battery in hopes of re-setting the ECU and take it out of "security mode" and now the car starts but the engine just aberly runs !!! Help car is now un-drivable !! :-(((
Old Feb 19, 2006 | 11:15 AM
Lugnut's Avatar
Default RE: HELP : Engine barely runs ! (C240) after battery dis-connect
Do it again. Disconnect ground cable first, then positive. Touch the two together for 15 seconds. Reconnect positive cable first, then negative.
Old Feb 19, 2006 | 11:53 AM
MwCH's Avatar
Well what is that supposed to do ?
Old Feb 19, 2006 | 11:56 AM
MwCH's Avatar
Lugnut - Thanks for the reply ! never mind why it works : I'l go'n do it right now ! be back in 15 minutes with results ....
Old Feb 19, 2006 | 12:08 PM
MwCH's Avatar
I did what u said lugnut : disconnected Negative, then positive connected 2 together 15 seconds thenput pos on then neg. NO CHANGE car still starts but will not rev ..... help can't even move car to my garage !
Old Feb 19, 2006 | 12:21 PM
sleepwalker's Avatar
will start but won't rev?
it must rev first before starting.
clean those battery connectors. nust be poor contact.
Old Feb 19, 2006 | 12:33 PM
MwCH's Avatar
No probleme with battery connectors : this is an ECU issue for sure ! engine starts but just idles will take a few revs but then barely idles. help !
Old Feb 19, 2006 | 06:31 PM
Lugnut's Avatar
I think it might be mechanical. I don't know what, though It's takes just a little bit of time or miles for ECU codes and modes to set. The ECU won't instantly be in limp mode after a reset.
When the car first did this, had it been sitting for over a day?
Old Feb 20, 2006 | 04:44 AM
  #9
MwCH's Avatar
No, the car was driven the day before, like I said all was ok (no warning lights on the dash) except that gas mileage was starting to go up and idle wasnot perfect - nothing bad but it would stumble some especialy when cold.
All I did was dis-connect then re-connect the battery....
Old Feb 20, 2006 | 06:26 AM
  #10
check pressure from service valve. maybe blocked fuel filter.
i know your engine and i never heard such problem with ecu before.
[IMG]local://upfiles/1/EFC7CEF4D7FC448EAACB715BBA8C9CB1.jpg[/IMG]
