Help with high idling
Old Jun 15, 2005 | 10:43 AM
edl100's Avatar
Default Help with high idling
I have a 96 E230 w210. My problem is that the car has a high Idling at around 1500 rpm without A/C. When the A/C is turned on, the idling goes to normal at about 700-800 rpm. This is the same whether the engine is cold or at normal temp.
Is there some sort of relay, sensor etc, that controls this idling? What is the fix for this?
Thanks for any help
Old Jun 17, 2005 | 12:47 AM
sleepwalker's Avatar
Default RE: Help with high idling
okay, i got no idea how it is ut you may start looking for
*air leak.
the intake manifold pressure should be between 380-400 mbar. spray the intake manifold flanges and connections with carburator cleaner to indetify leakage location. you may use water also.
check vacuum lines. seal off individually to isolate leakage.
**idle contact does not close or only closes intermittently.
test throttle linkage. disconnect connecting linkage from throttle actuator of idle speed control actuator.
place connecting linkage without tension against ball head of throttle actuator.
shorten linkage length of conneting linkage by adjusting two complete clockwise revolutions.
reconnect connecting linkage.
*** test coolant temperature sensor. on low temperature, the idle speed is higher so check if it is functioning properly.
[IMG]local://upfiles/1/D4AFA9B3021E458484EF559751312B2D.jpg[/IMG]
Old Jun 17, 2005 | 12:57 AM
hope this will make your analysis easier.
gusto mo punta ako dyan..? .
[IMG]local://upfiles/1/D3D3F5AB1CBB45BD9418E9BDA0DC1E86.jpg[/IMG]
Old Jun 17, 2005 | 08:31 AM
edl100's Avatar
Thanks.
I'll try your suggestions if my powers permit me.
If I can't solve it, I'll try my local MB mechanic on the streetcorner.
Of course, punta ka dito!! my treat.
Old Jun 17, 2005 | 09:45 AM
kailangan may malamig na beer saka andoks liempo ang pulutan! hanggang 3 bottles lang naman ako, hehe.
miss ko na food natin.
Old Jun 17, 2005 | 10:38 AM
edl100's Avatar
Correct!!
You read my mind sa inuman. Anytime!!
Nakaka-miss talaga ang inuman dito sa Pilipinas.
Old Jun 17, 2005 | 10:51 AM
edl100's Avatar
Anyway, regarding the car na malakas ang idling and malakas din sa gas ngayon.
As you said, I think that coolant temp sensor may be the culprit. If the car is cold, normally the idling is high as in most cars too. But if it is in operating temp, it should go down. I assume the sensor is telling the throttle to increase the idling if it is broken?
BTW, how come the idling goes back to normal when the Aircon is ON? Na-bypass na ang coolant temp sensor since the A/C is turned on?
How can a regular guy like me check the sensor? And where is it located? beside the thermostat housing?
I checked the throttle body, actuators etc. and they all seem fine to me. The air leak is possible too. I'll let a professional mechanic check it too be sure.
Pag na solve natin to, siguradong mag beer tayo pag dating mo dito
Old Jun 14, 2006 | 01:41 AM
unbugai's Avatar
Default 300e reving up and stalls when not giving gas?
i have a 93 mercedes 300e 2.8...when the car is started it will sometimes run normal and then start to loose and gain rpm?and if it is put into gear the car automatically stalls, it will keep reving up and down when in park but the same second u put the car in any gear it stalls? any one have a clue what might be the problem?
Old Jun 14, 2006 | 10:39 AM
  #9
Default RE: 300e reving up and stalls when not giving gas?
you have different model.
post a new thread.
ozizzel
May 27, 2009 05:24 AM
xabbeyroad
Apr 13, 2009 03:06 PM
theycallmetexas
Jul 13, 2008 01:00 AM
no respect
Mar 26, 2008 04:07 PM
Furby
Nov 24, 2003 12:16 AM
