electric prob
Old Mar 4, 2006 | 02:14 PM
paulie's Avatar
Default electric prob
hey guys/gals, I have a mercedes E240 1998 V6 and the car starts no problem but 10 mins into a drive and the engine cuts out when its warmed up. It takes 25 mins and it will start again but the engine cuts again after 5 mins. CAN SOMEONE HELP!! PLEASE
Old Mar 4, 2006 | 11:22 PM
sleepwalker's Avatar
Default RE: electric prob
fuel filter good?
some got the same symptoms with faulty crankshaft position sensor.
Old Mar 6, 2006 | 09:48 PM
paulie's Avatar
HEY Sleep, i got the crankshaft position sensor today, getting it fitted tomorrow. let you know what happens. thanks sleep
Old Mar 12, 2006 | 11:53 PM
paulie's Avatar
hey sleep, thank you for your help with the problem i posted with the E240 cutting out, We fitted the crank shaft sensor and the car is working fine now.
Old Mar 13, 2006 | 02:07 AM
you're welcome.
i hope that would fix the problem.
Old Aug 2, 2006 | 06:52 PM
paulie's Avatar
Default RE:E200 back fireing when warm
hi sleep just wondering if you can help with a problem??? I have an E200 merc 1997> the car starts ok but will not rev with out poping and back fireing. The car cuts out when it is warm and the air flo sensor and crank shaft pos sensor has been changed. there seems to be no power. Can you help sleep?? thanks for now paulie
Old Aug 8, 2006 | 10:23 PM
kurt08's Avatar
Default RE: RE:E200 back fireing when warm
Could be a vacuum leak or poor ground connections. crank and cam shafts alignment could also be the problem.
Old Aug 17, 2006 | 10:39 AM
paulie's Avatar
hey kurt found the problem with the e200, it was fuel pump loosing presure when heated up. thanks for the reply. paulie
Old Aug 31, 2006 | 11:29 AM
  #9
paulie's Avatar
Default E class 280 avandgarde 1998 model
hey guys and gals, strange thing happening when im driving my merc at the rear/back end of the car. i.e im getting a slight wobble, strange i know, tell me about it. This happens when theres two or more people in the back and when im goin around a bend on the road or if im on the motor way and a gust of wind hits the side of the car i can feel it. Im just wondering if any of you have come across this. I put new shocks on the rear aswell and the bushills seem to be fine. Thanks Paulie
damsy
Jul 28, 2006 11:32 AM
gkm24
Feb 24, 2005 12:43 PM
abohlig
Jan 22, 2005 11:00 PM
demeterial
Nov 2, 2004 09:38 PM
Kenny
Dec 12, 2003 09:42 AM
