Distributer Cap
Distributer Cap
1989 300E
There are three screws that hold on the distributer cap on the front of the engine above the water pump. The top two are easy the get to but the third is underneath the cap that is almost impossible to get to. What is the trick to get to this one? Special tool?
Thanks for the help!
RE: Distributer Cap
It should be a 5mm allen. I use a 1/4 drive long ball allen. It is a cornwell socket that is about 3-4 in in length. If you use a ball allen, be careful if the screw has been overtightened because the ball can break off. If tight, use a standard non-ball allen
bimmerautoservis
10-16-2009 03:05 PM
