Disconnect Drive Shaft?
I will be towing me sister's 1998 E320 from Northwest Arkansas to Phoenix next month. Being a RWD vehicle, it makes the tow dolly a bit more complicated than with many cars.
Does anyone have any experience disconnecting the drive shaft for towing? Any issues reconnecting it at the destination? Seems like a simple enough process, but I've never worked with Mercedes much before, so I thought I'd ask the experts.
Thanks for your replies!
they are 19mm nuts and bolts. some are 18mm. disconnecting it is ok but i guess youll be letting it hang down. because actually removing the shaft is more involved and youll need a lift to get to everything.
I'll find something to just hang it in place for the tow. Sounds easy enough, thanks!
190e, 98, disconnect, disconnecting, dolly, drive, driveshaft, e320, e350, mecedes, mercedes, shaft, stuck, tow, towing
