CLK 200 Rear Drive Shaft
Old Dec 11, 2006 | 12:12 AM
davecut's Avatar
Default CLK 200 Rear Drive Shaft
I have a 6 year old CLK which I bought from John R Weir in Aberdeen, Scotland. It has been regularly serviced there. I put it in for service and MOT a couple of weeks ago. I was horrified when I was told that the cost would be about £2000. The main item was the car needing a new rear drive shaft at a cost of about £1000. I believe this to be totally unacceptable for a 6 year old Mercedes with 65,000 miles on the clock. Neither John R Weir in Aberdeen or Mercedes are being helpful about this. I expect Mercedes to pay the full cost of the rear drive shaft repair and to pay towards some of the other repairs as well. I believe that there must be either a design fault or a manufacturing fault with the rear shaft for such an early failure to occur. This car has needed an excessive amount of repair work since it was purchased which I assume can be put down to the ongoing Mercedes quality problems.
Has anyone else had problems with such an early failure of a rear drive shaft? Thanks.
Old Apr 19, 2007 | 12:13 PM
davecut's Avatar
Default RE: CLK 200 Rear Drive Shaft
You might all be interested to know that this is ongoing. Apparently a failure of a rear drive shaft after 60,000 miles is considered acceptable by Mercedes. They have offered £200 as a "goodwill" gesture which means they expect me to fork out the £800, so there's not much goodwill there! John R Weir are making the problems worse with incorrect invoices.
Old Apr 19, 2007 | 07:12 PM
BlueSilver's Avatar
Honestly, if £2000 is a problem, it might not be the right car for you.
Blue
Old Apr 19, 2007 | 07:14 PM
BlueSilver's Avatar
Did you buy it new? Is it still under warranty?
Blue
Old Apr 20, 2007 | 09:12 PM
johncrompton's Avatar
Blue silver - £2000 is alot to spend on a car thats only done this mileage & is a MB - I cant believ you would post a reply telling someone that their car may not be for them if they are concerned about a £2k bill - you sound like a big fat idiot to me!
Old Apr 20, 2007 | 10:51 PM
BlueSilver's Avatar
Johncrompton, NO, £2000 is almost nothing compared to some recent repairs here in the US. A set of tires here costs more than£2000, or approximately $1000US. What happens when the tires need replacing?
Blue
Old Apr 20, 2007 | 11:13 PM
BlueSilver's Avatar
Or a new tranny, for example.
Blue
Old Apr 21, 2007 | 07:21 AM
Check the US dollar to UK pound conversion Blue, £2000 pounds = £4000 dollars not the other way around.
Old Apr 21, 2007 | 08:51 AM
  #9
davecut's Avatar
Guys,
Just to clarify the situation. I bought the car new but's it's not under warrenty now. On the serviceafter 6 years I was faced with a bill for £2000 (4000 US dollars) for a service and MOT which is clearly excessive. Of the £2000, £1000 was to replace the rear drive shaft. Mercedes says a failure like that is acceptable, I believe that is totally unacceptable and that Mercedes should pay the full £1000 repair cost. Mercedes are being extremely unhelpful about the whole thing. I believe that the rear drive shaft but have been faulty when it was supplied or not fit for purpose. Thanks for all your interest.
Old Apr 21, 2007 | 11:05 AM
  #10
BlueSilver's Avatar
ouch, you're right about the currency.
Gulp.
I completely withdraw my arguement.
Blue.
